Strong yellow cast on Oly OM-1 RAW files using as LightRoom plugin MacOS
I’m propably as confused as You. There really is no factor I can point out that might be causing this. It’s a lottery so to say.
A lottery is not the ideal behavior when using an image processing application unfortunately.
If you get the color shift and reprocess the original image do you always get a color shift again?
Yes I do and it happens with both of my Mac’s.
Uppdate: I have a Lumix DX80 body as well as my 3rd camera and I can’t reproduce the yellow cast with it so I wonder wether the problem could be with the OM-1 file handling?
So far it seems like it’s only an issue with the OM-1. I was able to reproduce a color shift with some images, and it was consistent with that image.
I brought this up with my team so we can look into a fix.
Good news! The color shift problem has been there from the day OM-1 was released but it was fixed once and came back being better and worse during times. Let’s hope you end up with a permanent solution.
Hello,
just to keep this thread alive the occational yellow cast with OM-1 files is still there with v.2.0.0
