Starlight Precise 2.6 spills into shared system memory and drops to 0 FPS on RTX 5080 16GB
Hello,
I am experiencing a repeatable performance problem with Starlight Precise 2.6. Other Topaz enhancement models work normally on the same system; this problem only occurs with Starlight Precise 2.6.
System specifications
  • GPU: NVIDIA GeForce RTX 5080, 16GB VRAM
  • CPU: Intel Core Ultra 7 270K Plus
  • RAM: 96GB DDR5
  • OS: Windows 11 25H2, build 26200
  • NVIDIA driver: 610.88
  • Topaz Video: 1.7.1
  • Two 4K displays
  • Intel integrated graphics also available
Test settings
  • Source: 9-second H.264 High Profile video
  • Resolution: 1280×720
  • Frame rate: approximately 24 FPS
  • Starlight Precise 2.6
  • Sharpness/Softness level: 1
  • Output: 2560×1440, 2× upscale
  • No frame interpolation or additional enhancement models
  • The complete source file is exported; no In/Out trim is being used
What happens
At the beginning of the export, the RTX 5080 appears to work normally. GPU power consumption remains above 250W and processing progresses for approximately two or three minutes.
After that, performance suddenly collapses:
  • GPU power drops from over 250W to approximately 84W and never recovers.
  • Processing speed drops to 0.0 FPS.
  • The estimated remaining time increases to more than 21 hours for a nine-second video.
  • GPU temperature is only around 46°C, so this does not appear to be thermal throttling.
  • GPU clocks remain high, but GPU memory-controller utilization drops to approximately 3%.
  • Neuroserver begins using a very large amount of shared system memory.
During the stalled state, I measured approximately:
  • 10.8–11.1GB dedicated GPU memory used by neuroserver.exe
  • 14.6GB shared GPU/system memory
  • Approximately 23GB working-set RAM
  • Approximately 33GB private committed memory
The GPU may still be reported as highly utilized, but power consumption and actual processing throughput are extremely low. This looks like VRAM oversubscription followed by NVIDIA/Windows system-memory fallback and severe memory-transfer thrashing.
A shorter five-second clip has completed successfully before, but nine-second and longer clips repeatedly enter this stalled state. A 30-second 720p clip can produce an estimated processing time of more than one day.
Troubleshooting already performed
  • Completely reinstalled Topaz Video
  • Restarted Topaz Video and Windows between tests
  • Tested the Topaz maximum-memory preference at both 70% and 100%
  • Confirmed that no other GPU-heavy applications were running
  • Confirmed that temperatures, GPU clocks, PCIe link and power delivery were normal
  • Confirmed that other Topaz models work normally
Changing the maximum-memory preference did not appear to constrain Starlight Precise 2.6. In the logs, Neuroserver was still launched with:
--max-gpu-mem 16
This occurred even when the application preference was set to 70%.
Questions
  1. Is this a known memory leak or VRAM-oversubscription issue in Starlight Precise 2.6 or Neuroserver?
  2. Why does the application continue to pass --max-gpu-mem 16 when the maximum-memory preference is reduced?
  3. Is there a supported way to force a smaller temporal batch, tiled processing, or a lower effective GPU-memory budget such as 12GB?
  4. Is 16GB VRAM genuinely expected to process 720p → 1440p footage with Precise 2.6 without falling back to shared system memory?
  5. Are there any additional logs or diagnostic files I can provide to help reproduce this?
The official requirements recommend 16GB VRAM for Starlight Precise 2.6, so I would expect this 720p test to remain usable on an RTX 5080.
Thank you.
  1. There is no known vram leak at the moment. For 16gb gpu, the model will try to use the most. If there is other program occupying vram, there can be a conflict and forcing the slp to spill vram. We recommend to reduce gpu usages by other programs.
  2. There is a known issue where the ui set max-gpu-mem is not used by the model. We will fix it in the next release.
  3. Same as 2.
  4. It is expected to process such resolution without falling to shared system memory.
  5. At the moment we do not need any log files. Thanks for offering!
It honestly scares me to see this post because I’m planning on getting the same GPU specifically for Starlight Precise rendering. I’ve been seeing very similar behavior on my 7900 XTX after switching to Starlight Precise 2.6. I managed to get a few clips to work by splitting the footage into 1‑minute segments, but that workaround isn’t reliable. One of my 480p videos fails no matter what, while a 720p sample surprisingly worked once I segmented it.
The pattern is always the same: the first few minutes look normal, VRAM stays within budget (around 14GB), and then Starlight starts over‑allocating VRAM. Once it pushes past the limit, the export eventually fails.
I’ve gone back and forth between Topaz 1.6.1 and 1.7.0 several times, and I just can’t get Starlight 2.6 to behave predictably. I’ve reverted to Starlight 2.5 for now because it consistently stays within VRAM limits, and that seems to correlate with successful full exports.
EDIT/UPDATE: After bouncing back and forth between 1.6.1 and 1.7.0 trying to figure out what was going on with my system, I managed to get most of the footage to process by breaking the project into 1‑second segments. VRAM and system usage still max out, but this method lets the model finish clips that otherwise stall.
It’s possible my projects were failing for a different underlying reason, but I wanted to note that I’m also seeing VRAM consistently maxed out and the “Max GPU Memory” setting in the UI doesn’t seem to reduce VRAM usage when set lower.
@balazsnemeth.com @mcyyxsky1986 please try the new beta that was just released to see if this issue continues.
Topaz Video 1.7.1.2.beta
Hi Kyle,
I’m experiencing the same Starlight Precise 2.6 issue on an RTX 5080 16GB. The render starts normally and then suddenly drops to 0.0 FPS and gets stuck.
Topaz Support has already confirmed that my issue appears consistent with the known RTX 50-series Starlight Precise 2.6 memory-management problem, and I have sent them my logs and system profile.
I have a valid Topaz Video license and already requested access to the Video Beta Testers group, but my membership is still pending. Could you please approve my request or give me access to the Topaz Video 1.7.1.2 beta so I can test the fix and report back?
Thank you!
You should be good now to access that beta.
RTX 5070 Ti 16GB, identical shared-memory spill with SLP 2.6, beta request pending, would like to verify the 1.7.1.2 fix
Hi Kyle, I am very advid user of SLP and was wondering if I could also test the beta? thank you very much. I am running both 4090 and 5090 rigs
thanks
I have been experiencing this exact issue on RTX 5070 Ti 16Gb. The beta version unfortunately had not fixed it for me. Same exact behavior.
Can you email the support team the logs from the beta release showing this behavior? Want to get the dev team to look into this. help@topazlabs.com
Can you also try reducing the avaiable vram setting in the topaz video app. set it to lower of 14gb or 12gb. Thanks.
Done.
I’ve tried, with memory limits ranging from 65%-95%. No effect.
