Starlight Precise 2.6 errors unless I start Starlight Mini first
If I try to run an SLP Enhancement process it immediately shows as Error in the Export queue. However, if I run the same video from the same source through SLM instead it starts the process. I then run the same video source through SLP which then goes into the queued mode waiting behind the SLM process. If I then canx the SLM process it does so, and then the queued SLP mode starts its process and is successful. Something is wrong here.
Can you share the logs for review here? Not sure why running Starlight Mini first would change the aspect of the Precise model and how it runs.
