Hello Topaz Labs Support Team,
I would like to report a reproducible issue with Topaz Video AI when using Starlight Mini, where GPU processing stops during encoding even though the job appears to continue.
Environment
Product: Topaz Video AI
Version: 1.2.0
AI Model: Starlight Mini
GPU: NVIDIA RTX 5070 Ti
VRAM: 16 GB
OS: Windows 11
Driver: Latest NVIDIA Studio/Game Ready driver
Input video: FHD (1920×1080), 30 FPS
Issue Description
When encoding with Starlight Mini, the process starts normally and GPU usage is initially observed. However, during the same encoding job:
GPU usage suddenly drops to 0% (confirmed via NVIDIA App and Windows Task Manager).
Topaz Video AI continues to display “Processing” and does not report an error.
Encoding speed effectively stalls or becomes extremely slow.
GPU usage does not recover for that job.
Restarting Windows temporarily resolves the issue, but the problem frequently reoccurs during the next encode, especially with longer videos or multiple encodes in one session.
Observations
The issue occurs even with FHD input and sufficient VRAM.
VRAM is not fully exhausted when the problem happens.
Restarting Topaz Video AI alone does not fix the issue once it occurs.
Restarting Windows resets the behavior temporarily.
Switching to other models (e.g., Artemis / Proteus) does not trigger the problem as often.
This appears consistent with a CUDA context or memory handling failure specific to Starlight Mini.
Expected Behavior
GPU utilization should remain active throughout the entire encoding process, or the application should fail gracefully with an error if GPU processing cannot continue.
Suspected Cause
Based on behavior, this may be related to:
CUDA context loss or improper cleanup
GPU memory allocation / deallocation instability
A driver-level GPU watchdog interaction triggered by Starlight Mini
Temporary Workarounds
Restarting Windows between encodes
Processing videos in short segments (5–10 minutes)
Avoiding batch processing
Reducing Starlight Mini feature load
Request
Could you please confirm:
Whether this is a known issue with Starlight Mini in version 1.2.0
If there is a recommended stable configuration or upcoming fix
Whether debug logging would be helpful for further diagnosis
Thank you for your time and for your continued work on Topaz Video AI.
