I want to use it locally Starlight Mini but seems is not working. Could be the model corrupted. I want to kknow how can I delete it and force a new doanload, or download and overwrite it.
Try these steps to do a full uninstall and reinstall.
Open Windows System Settings>Apps>Uninstall
Delete any files and folder for the main drive - C:\Program Files\Topaz Labs LLC\Topaz Video AI\
Open the Registry Editor on your system. - Windows Key+R will open the run option and then type regedit. Click yes when it prompts.
Navigate down to the following folders and right-click on it to delete it.
I. Computer\HKEY_CURRENT_USER\Software\Topaz Labs LLC\ Topaz Video AIII. Computer\HKEY_LOCAL_MACHINE\Software\Topaz Labs LLC\Topaz Video AI
Reboot your system
Reinstall the app from a clean download using this link: Video AI v7.1.0 - windows installer
