Star Trek - Deep Space Nine Upscaling Project by Leland Kovich(PAL-DVD to 1080pHD in 4:3)
This is a project/showcase dedicated to showing the possibilities of using software based-solutions (including Topaz Video Enhace AI) to restore/upscale the SciFi-Series “Star Trek - Deep Space Nine”.
The source for this project are the PAL-DVDs (european market).
The software/programs involved is/are:
  • DVDshrink (extracting raw data from PAL-DVD discs)
  • meGui (adjusting audio stream - lower/correct pitch to adjust for PAL-shift towards 23,976 FPS)
  • StaxRip (apply various filters to enhance viceo quality and adjust from 25 FPS to 23,976 FPS)
  • Topaz Video Enhance AI (3-step enhancement and resolution upscale (various models/parameters)
  • DaVinci Resolve (apply various filters to enhance video quality and encode to 1080pHD)
  • mkvToolnix (merge video and audio-streams)
  • Handbrake (compress/downsize videofile)
So, here you go:
So, here we go with DS9 season 1, episode 1/2 “Emissary”.
Image Gallery (with slider): DS9 UP 1x01;02 - Imgsli
Here are the images from the PAL-DVD - Part 1:
Here are the images from the PAL-DVD - Part 2:
Here are the images from the PAL-DVD - Part 3:
Here are the images from the PAL-DVD - Part 4:
Here are the images from the Upscale - Part 1:
Here are the images from the Upscale - Part 2:
Here are the images from the Upscale - Part 3:
Here are the images from the Upscale - Part 4:
So, here we go with DS9 season 1, episode 3 “Past Prologue”.
Image Gallery (with slider): DS9 UP 1x03 - Imgsli
So, here we go with DS9 season 1, episode 4 “A Man Alone”.
Image Gallery (with slider): DS9 UP 1x04 - Imgsli
