Stabilise and watermarks
Hi there
Just starting to use Topaz so on a steep learning curve. I have some 1080p sports footage that I am upscaling - some the shots are long distance so there is some jitters in the filming. I tried to use stabilise - which did work well fixing the movement , but the original logo watermark on the videos flickers all over the place. Quite understandable, but does anyone know any workarounds ? Is this a feature that could be added to stabilise in the future?
Stabilization is a model and feature in the app that can be used on your video source. The Topaz watermark will only be applied when the app is being used in a trial mode. Or are you referring to a different logo watermark on the video from the original source material?
Yes the watermark is on the original footage I have the full Topaz app.
Can you post a screenshot or small sample to showcase this? I am trying to make sure I understand what is going on to best assist.
