Split view doesn't work smoothly. Images not horizontally aligned to each other
Split view doesn’t work smoothly. Images not horizontally aligned to each other
There have been issues with the split view that are being resolved.
When you are using it, are you applying any upscaling to the video?
Yes. SD to 4k
That large of a jump can cause some shifts but if you reset the zoom level after running a preview it should update both sides of the split view to have them match. Can you send me a screenshot of what you are seeing and the logs to have the devs review? You can email them to me at help@topazlabs.com if you do not wish to post on the forum.
