I’m mainly a photojournalist so i try to not to use for the moment AI tools for this kind of photo unless they have a commercial usage, i always had problem with sharpen AI before and photo AI now, both were creating artifacts or excessive noise so that i had to use portions of the image mounted as layer on PS, with the last release ( 3.3.0 ) everything blown ( on my macbook air m3 ) did some fast test of some photos and instead of sharpening faces there is a blurring, and the general sharpening does more or less nothing that you can do with an old sharpening in PS …funny 'cause thay just asked for money for the updates
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
