Hi. I purchased the HP Envy Laptop 17-cr1XXX a year ago so I could run the Topaz programs without the lag. They were doing GREAT! I am pretty sure I have plenty of laptop resources for Photo AI but it is much slower. I am thinking it might be the graphics card? (I did reinstall a few times)
I am a photographer so I truly hope to get this back up to speed if I can? Here are my laptop specs:
|Processor|13th Gen Intel(R) Core™ i7-13700H 1.70 GHz
|Installed RAM|64.0 GB (63.7 GB usable)
|Device ID|34F2EEEF-EEAE-434A-AC26-04158521037D
|Product ID|00342-21073-98796-AAOEM
|System type|64-bit operating system, x64-based processor
|Pen and touch|No pen or touch input is available for this display
Display/Graphics Card:
Intel(R) Iris (R) XE graphics
Graphics Max Dynamic Clock 1500 MHz
TDP 28 W
PCI Express Configurations Up to x4 Gen4
Memory Specifications
Graphics Memory Interface 128 bit
Graphics Memory Bandwidth 68 GB/s
Graphics Memory Speed 4267 Gbps
I/O Specifications
Number of Displays Supported 3
Graphics Output DP 1.4 w/ HDR, HDMI 2.0b
Max Resolution (HDMI) 4096 x 2160@60Hz
Max Resolution 7680 x 4320@60Hz
Features
H.264 Hardware Encode/Decode Yes
H.265 (HEVC) Hardware Encode/Decode Yes, 12-bit
Supported Technologies
DirectX* Support 12.1
Vulkan* Support 1
OpenGL* Support 4.6
Advanced Technologies
Intel® Adaptix™ Technology No
Intel® Deep Learning Boost (Intel® DL Boost) on GPU Yes
Any ideas?
