Setting default settings
in the new update how do you set defaults, for example when I do a group of graphics, I want the upscale set to graphics, when using autopilot. Are there options for this?
Go to Preferences>Upscale and Resize and then the Default Model pulldown. Mine is set to Auto, but you can change it to Graphics.
Ahhh thank you so much, I scrolled right past that. appreciate the reply.
