I believe in Auto settings, TVAI checks every 8 frames to auto-set the parameters.
This slows down processing greatly. Can we have a manual setting for this, or possibly change it “scene change” as a trigger for auto settings.
I am working on a project to upscale DVD to FHD. With manual settings in Proteus I get about 40+ frames/s. Using Auto, the speed drops to just over 20 frames/s.
I’m voting for this because I know I can change the amount in the CLI. It would be nice if everyone could change it too. (Vote for your own idea. )
CLI?
do tell please.
$ ffmpeg -h filter=tvai_up
tvai_up AVOptions:
model <string> ..FV....... Model short name (default "amq-13")
scale <int> ..FV....... Output scale (from 0 to 4) (default 1)
w <int> ..FV....... Estimate scale based on output width (from 0 to 100000) (default 0)
h <int> ..FV....... Estimate scale based on output height (from 0 to 100000) (default 0)
device <int> ..FV....... Device index (Auto: -2, CPU: -1, GPU0: 0, ...) (from -2 to 8) (default -2)
instances <int> ..FV....... Number of extra model instances to use on device (from 0 to 3) (default 0)
download <int> ..FV....... Enable model downloading (from 0 to 1) (default 1)
vram <double> ..FV....... Max memory usage (from 0.1 to 1) (default 1)
estimate <int> ..FV....... Number of frames for auto parameter estimation, 0 to disable auto parameter estimation (from 0 to 1e+06) (default 0)
Thanx. A good shortcut, not requiring to learn the whole CLI shebang.
