September Release - Topaz for Web
Several big announcements this month: Bloom is joining Topaz for Web, and Topaz is now on Android. Plus, prompting and multiple outputs on the web, Starlight Fast 3, our fastest Starlight yet, a new Speed Boost option for Starlight Precise 2.6, and a new Portrait Enhance workflow. All in the Topaz for Web September Release.
:mobile_phone: Topaz is now on Android
The Topaz app is now available on Android. Enhance, upscale, and restore your photos right from your phone, with the same workflows and AI models you use on the web.
It launches with everything from the latest iOS release.
Download it Now: Google Play Store Link
We’re sunsetting the Bloom app and bringing all Bloom users into Topaz for Web. The transition starts today, and Bloom will close on October 13, 2026.
Existing Bloom subscribers keep their current plan, now with Pro Image access: unlimited processing up to 256 MP, with up to 8 images at once.
Prompting & Multiple Outputs
The creative controls you use in Bloom are now in Topaz for Web. Upload a single image to the Bloom 2 or Creative Upscale workflow to unlock extra options:
  • Prompting: Guide the result by describing what you want to see.
  • Multiple Outputs: Generate several variations in one run and pick your favorite.
These options appear whenever you run one image at a time. Batches of multiple images use the standard workflow settings.
:rocket: New Models
Starlight Fast 3
Starlight Fast 3 is the next generation of our Starlight Fast line. It’s a diffusion video enhancement model built for quick iteration and deadline-driven work, for both GenAI and archival footage.
It renders up to 4× faster than Starlight Precise 2.6 with comparable 4K quality. At 1080p output it processes up to 7 frames per second, so a 10-second clip finishes in under 40 seconds. It also uses scene splitting, which detects cuts within a clip automatically to keep results stable and consistent across scene changes.
What’s new in Starlight Fast 3:
  • Up to 4× faster than Starlight Precise 2.6
  • Comparable 4K output quality to Starlight Precise 2.6
  • Significantly improved skin, text, and fine detail over Starlight Fast 2
  • Scene splitting for better temporal stability at cuts
Starlight Fast 3 replaces Starlight Fast 2
:film_frames: Video Model Updates
Starlight Precise 2.6 Speed Boost
Starlight Precise 2.6 now has a Speed Boost option. It renders up to 10× faster for 2× the credits, with the same Precise 2.6 quality.
Which should you use? Pick Starlight Fast 3 when you want speed at standard cost. Pick Precise 2.6 when you want the highest quality, and turn on Speed Boost when you need that quality fast.
:framed_picture: Image Model Updates
Wonder 3.5: Fixed an issue that caused visible tiling in some results.
:card_index_dividers: Workflows
Portrait Enhance (new)
A dedicated workflow for decent to high-quality portrait photos that need a professional finishing touch. Portrait Enhance combines lighting and color correction, denoising, sharpening, upscaling, and face recovery in a single run, with no back and forth between tools.
  • Lighting & Color: None, Subtle, or High. Subtle gives a natural lift to tone and balance, and High is best for flat or underlit flat shots.
  • Denoising: Runs automatically and cleans up grain and digital noise.
  • Sharpen: Toggle on for added clarity and edge definition.
  • Upscale: Choose your output scale while preserving natural detail.
  • Face Recovery: None, Subtle, Medium, or High. Higher settings bring out more definition in skin, eyes, and fine features.
General Enhance is back on mobile. You asked, we listened.
:warning: Known Issues
HDR with Starlight Fast 3 and Speed boost: HDR isn’t supported yet when using Starlight Fast 3 or Starlight Precise 2.6 Speed Boost. A fix is on the way soon.
Get Started
Jump in at app.topazlabs.com. For guides and support, visit docs.topazlabs.com and click Support in the bottom right.
We can’t wait to see what you create.
— The Topaz Team
@isaiah.bolinger I hope the improvements in rendering speed in Starlight Precise 2.6 and the new Starlight Fast 3 will be coming soon to the desktop version as well! :sweat_smile:
