Hi, when I enable scene detection with 60 fps frame interpolation and export, I’m seeing “Initiating process… 0.00%” and “Scene splitting…” for a seemingly infinite amount of time.
I can confirm that none of the files I tested yield any results with scene detection enabled… Plus, judging by the version 1.7.0 changelog, the desync issue when using this feature wasn’t fixed… Looks like 1.7.0 is competing for the title of the worst release technically.
How long is the file and are there a lot of cuts? The process can take awhile to run through the entire video.
That being said we are seeing some issues with that feature and the team is investigating them. If you can share your logs that will help them out.
logsForSupport.zip (678.9 KB)
It’s just one cut that’s needed, video is around 5 seconds long
