Scale conversion (anamorphic input videos)
This involves adding a new crop setting: ‘Fill’, accompanying ‘Crop to Fill’ and ‘letterbox/pillarbox’ so that the rescaling indicated by the required resolution is applied, although this usually warps the image. The modification on the underlying ffmpeg command is very simple, for example for 8K output:
..., scale=w=7680:h=4320:flags=lanczos:threads=0,split=2[out1][out2], ....
I’ve tried it from command line and the result is the expected.
This would allow the deformation introduced by anamorphic lenses to be corrected in the same step.
Thanks for this suggestion! Our team is currently working on implementing support for anamorphic footage and we hope to have this update available very soon.
I have same request on how to fix anamorphic footage. Looking forward to a fix
So they are working on it since 1.5 years now? :thinking:
