Save file as 8 bit instead of 16 bit
Hi,
Is there a way to save the images as 8 bit color depth instead of 16 bit? I can’t find that option. Or possibly introduce it for future release. I’m currently opening 100s of images, saving them to 8 bit manually to do my work for compatibility reasons. Thanks.
Yes, when you use as a standalone application and Save you have the option to save 8/16 bit for both PNG and TIFF.
