would ryzen 3100 to ryzen 5900x make any difference on topaz video ai using the same GPU? (assuming you are using something like rtx 4080)
ryzen 3100 is slowest cpu that supports pcie 4. (at least on amd side)
It’ll definitely help.
I’ve upgraded from 5800x to 9700x and the difference was noticeable.
Every extra core and frequency boost will help.
5800x to 9700x also means ddr4 to ddr5 so that’s little bit different. 3100 to 5900x is still same ddr4 running at same ram speed.
