RTX 4060 TI or RTX 3060 TI GDDR6X for TVAI?
Hello.
I have the GTX 1070TI and I’m going to buy a new card.
Is the 4060 TI better or worse than the RTX 3060 TI GDDR6X for TVAI?
In my country the 4060 TI costs $700 and the RTX 3060 TI costs $560, I converted it into US dollars to make it easier to understand.
I appreciate anyone who can help me.
Topaz Video AI  v3.3.3
System Information
OS: Windows v10.22
CPU: AMD Ryzen 7 2700X Eight-Core Processor           15.927 GB
GPU: NVIDIA GeForce GTX 1070 Ti  7.8838 GB
Processing Settings
device: 0 vram: 0.99 instances: 1
Input Resolution: 1920x1080
Benchmark Results
Artemis		1X: 	02.87 fps 	2X: 	01.98 fps 	4X: 	00.80 fps
Proteus		1X: 	02.83 fps 	2X: 	01.93 fps 	4X: 	00.79 fps
Gaia		1X: 	01.00 fps 	2X: 	ERR fps 	4X: 	ERR fps
4X Slowmo		Apollo: 	03.45 fps 	APFast: 	14.22 fps 	Chronos: 	01.80 fps 	CHFast: 	02.86 fps
From all I’ve read so far I’d go for the 3060
			RTX 3060 Ti		RTX 3060	RTX 4060 TI
CUDA Cores 		   4864 		3584		4352
The new Nvidia cards have less CUDA.
I’m worried about the 4060 TI being worse than the 3060TI on TVAI.
Have a watch of this video.
His reviews are content creator biased not gaming.
Might help you a bit.
Really the 3060 Ti is better for me and it doesn’t cost more here in Brazil.
My motherboard is B450, PCIExpress 3.0.
The RTX 3060Ti will not have a limitation on my PCIExpress, while the RTX 4060TI will have a limitation on the B450.
Thanks for the video.
@menditsa
Goodnight.
I ended up buying Galax’s RTX 3060 TI GDDR6X.
Before.
System Information
OS: Windows v10.22
Processing Settings
Benchmark Results
After.
System Information
OS: Windows v10.22
GPU: NVIDIA GeForce RTX 3060 Ti  7.8496 GB
Processing Settings
Benchmark Results
Artemis		1X: 	13.50 fps 	2X: 	07.35 fps 	4X: 	01.98 fps
Proteus		1X: 	13.57 fps 	2X: 	07.52 fps 	4X: 	02.02 fps
Gaia		1X: 	04.46 fps 	2X: 	03.01 fps 	4X: 	01.96 fps
4X Slowmo		Apollo: 	17.56 fps 	APFast: 	38.70 fps 	Chronos: 	10.31 fps 	CHFast: 	16.48 fps
Nice improvement, well done. :clap:
