Retaining ALPHA channel transparency
Rendered a .mov video from After Effect with RGB plus Alpha channel transparency. Will the resulting Video AI rendered file retain the ALPHA transparency so that I can import that enhanced file back into After Effects to use in a 3D rendered video scene??
Unfortunately no, VEAI only exports RGB png or TIF even if your input is RGBA.
Damn, I was also searching for this option. My workflow for now is doing an upscale of each separately and then combining it again!
Is the option to export rgba sequences in the pipeline to be released in future updates? If so, it’d be an incredibly useful feature.
I am running into the same issue. I went through and exported out of AE twice one with RGB, and one with alpha. Don’t change the frame rate, just up scale. It seems to work alight, I had to feather the edges when brought back into AE.
We were having the discussion about upgrading to 3.0, and alpha support ended up being the deciding factor.
Hi, we are trying to add the software in our pipeline process but we found EXR is not saving alpha channels, is there any way to get them work? or is some feature you will add in the future?
@3doubles.produccione I’m not sure we fully support EXR files. Can you upload the file here so I can test it out.
Hey Tim thanks for answer so quick sure thing, thi is how it looks an example inside photoshop,
and this is how it looks after pass it trough the software, the alpha has missed
lgt_anim01.zip (2.1 MB)
I have been trying to modify your video-encoders.jason trying to get with the proper configuration but with no luck at all.
I wish you can help
Thanks so much :smiley:
Hey all, Alpha channel support would be great. One work around for those who need an alpha channel is to generate a black and white alpha matte from the footage that already has the alpha. You can do this easily in after effects with a white solid that is using your footage with an alpha as an “alpha matte”. Then just drop a black solid underneath. Export that and you should be able to run both passes through Topaz Video Ai. If the settings are the same, you should have a usable result.
I hope this helps
To upscale with alpha channel, you need to use video with PNG video codec
324325235
we tried that and with fast motions the RGB and alpha pass don’t fit 100% together, resulting in weird alpha situations
Has this been solved in version 4?
Alpha support added in version 5.2
Hello!
Could you confirm if the new Topaz v5.2.1 has support for alpha channel, and in what format does the sources need to be so topaz reads that alpha?
Best,
Tiago
I haven’t upgraded to check out new models (waiting on another sale which I initially got topaz stuff with), which can support alpha transparency, the trick I have been using which works pretty well with a little post cleanup is to simply export the alpha channel with Photoshop or something, and upscale that along with the original images, and than re-apply the upscaled alpha back with the upscaled image as alpha channel.
Whatever I do, I can’t seem to get the alpha channels to be maintained. Does it work when doing time stretching? (or does that matter?). Tried PNG Tried Quicktime. I’m on 5.3._
Alpha transfer currently does not support frame interpolation
