I tried upscaling an image created in midjourney, which was a portrait of a woman, which was supposed to look like a painting. Intentionally it had a slightly grainy look with visible brushstrokes. After upscaling the image looked too smooth, like an airbrushed photo, and the brushstrokes were no longer visible. Is there anything I can do to correct this? Maybe my settings are wrong? I only just started using Topaz.
Would you mind sharing a before and after example of the image you are working with? It would also help if you include a screenshot of the Right Panel showing which features you are using as well as their settings ![]()
