Dear Topaz Labs Team,
I hope this message finds you well. I’m writing to share some feedback regarding the user interface of Topaz Photo AI, specifically in relation to the Autopilot feature.
While I appreciate the convenience of the Autopilot’s suggestions for further image adjustments, I’ve encountered a recurring issue. As the software generates more suggestions, the option fields tend to shift downward in a somewhat abrupt manner. This often leads to a situation where, when trying to speed up the process, I accidentally click on the wrong option, as the one I intended to select has already moved out of view.
Would it be possible to modify the interface behavior so that the options remain more stable, or at least allow users to prevent them from shifting unexpectedly? This small adjustment would greatly improve the workflow and reduce the likelihood of accidental selections.
Thank you for your time and consideration. I look forward to hearing from you.
Best regards,
Wolfgang Kairat
