Request for a "safe mode" application launch feature
It would be very helpful if I can launch the application while holding the SHIFT key and have it NOT open the previously opened project. This would be a huge time saver. I don’t use projects anyways.
  1. A preference setting to NOT open the last project on launch.
  2. The ability to hold SHIFT during launch to reset all settings and NOT load the previous project.
moving this to the Ideas section to see if other users will vote on this for consideration.
Currently, I just delete the entire projects folder. This allows me to skip loading the previous project. Also, I should mention that the CANCEL button does nothing.
