Request | Create Subfolder for Exports
Right now I have to do this manually for each project and it’s a bit annoying to have to do it each time as I have many different folders, hard drives and directories so it always takes a minute to find the right original folder manually just to create a subfolder. If there was a sub option when saving to “original folder” if we had another option of “create subfolder in original folder” that would be great.
I didn’t see anyone else suggest this but it seems so obvious to separate the originals from modified ones in different folders, especially when working with a bunch of images.
Thanks.
Thank you for the great idea. I’ll be sure to bring this up to our product owners to better investigate the complexity of implementing this.
