I just purchased a new M3 Ultra Mac Studio with 96GB of storage and retested Starlight using V1.0.1 of Topaz Video.
I can now run Starlight (Beta) locally, though the render progress indicator is not working: It shows 0% and 0 fps continuously, but eventually the render queue shows “Done”. Is this a known bug that prevents updates to the progress indicator.
The model is running but it processing at less than 1 frame per second and the UI does not show that cleanly. The 0% issue though is odd as it should be progressing even if the speed is being shown as 0fps or less than.
Are you seeing this issue still in 1.0.3 or 1.0.4? If so, can you send the logs and a screenshot to the support team for follow up?
