RECOVER FACES ARTIFACTS | When using Upscale, Super Focus and Recover faces, visual bug
Topaz Photo super focus adds artifacts in top left
Hi James,
Our development team is aware of this artifact issue and is actively working on a fix. I’ve added your information to the existing ticket, and we’ll reach out as soon as an update is available.
In the meantime, please avoid applying Super Focus and Upscale together, as this triggers the issue. Instead, you can try applying Super Focus first, export the image, then apply Upscale in a separate session as a workaround.
We will update this thread as soon as there is a fix for the issue.
Thank you for quick response
