Number Format
Release numbers are formatted to convey information about the release:
version.feature.patch
Version: Major updates, often with compatibility changes or significant new models.
Feature: Adds improvements or new functionality within the same version.
Patch: Fixes bugs and applies minor refinements.
Factors to Consider
Are you looking for a previous release that:
- is compatible with hardware limitations?
- had a function that was preferred over the latest release?
- didn’t include a bug that the new version introduced?
Examples
If you’re having issues with compatibility, consider the current system requirements and choose an earlier version.
For example, use v6.3.3 for under-spec systems compatible with legacy requirements
Use v8.2.2 if you cannot update to the latest build of Windows 10
If you prefer functionality from a previous release, use the last feature release that included the functionality you liked better.
For example, use v7.4.4 if you do not want cloud-generative features
If you’re experiencing a bug that snuck into a new release, use a previous patch release that didn’t include the bug, or update to a newer patch that you haven’t yet installed.
For example, use v8.3.4 if you’re experiencing excessive model errors
Accessing Previous Installers
Installers are linked in posts for each release. Detailed notes are included, and community comments often provide helpful context about performance or known issues.
If you have any questions about releases or compatibility, please write to help@topazlabs.com for support.
