hello, can you tell me what would be the right settings on proteus for a 1080 to 4k video so that the image is clear and clean? thank you for your sharing
Totally depends on the type of video being used (live action, animated, mixed) and the quality of it. I recommend using the compare view, use the top left panel for the source and the other 3 with different settings until you find something you like. I also don’t recommend using the auto detect feature, most of time you can get results that look way better. Play around with each option individually so you can understand what each of them do and then figure out how they all work together. It’s basically plug and play after that with any video when you’ve learned everything.
