Project.tvai file
Hello. I am trying to find some lost Topaz video files, and I came across a project.tvai file in my documents folder. What is this file?, and is it possible to recreate a lost video file from this? Also, normally where are the saved (i.e. finished) topaz video files stored at on a computer? Thanks, Brian B.
The project file does not contain the actual video file it will just include a reference to the file but it can not be used to recover the file.
The exported and processed videos will be saved to the original video location or where you set it to export to if you used the Export As option.
