With the Sharpening Feature, you can select the subject and sharpen it. I think it could additionally be handy to be able to do the opposite too, e.g. select the background and make it more blurry to push the focus of the subject even more.
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea
