I am having a problem installing Topaz Sharpen AI. I don’t have much room left on my C: drive so I am doing a custom install on my D: drive. When I change the install location of Sharpen AI to D:Program Files\Topaz Labs LLC\Topaz Sharpen AI and click next, I get the following message:
“D:\Program Files\Topaz Labs LLC\Topaz Sharpen AI is not writable by the current user.”
I installed Photo AI, NoNoise AI and Gigapixel AI successfully to my D:Program Files\Topaz Labs LLC.… drive. I’m not sure what to do to get Sharpen AI installed.
Can anyone help? Thanks.
I’m having the same issue. Anyone have any suggestions?
I got help from Topaz technical support. There is a known issue with Sharpen AI install where it needs certain permissions for a folder. The easiest workaround is to let the install program create the Sharpen AI folder rather than create it yourself. Start the installation with the Sharpen AI folder not created and when prompted for program location just change the drive letter.
Thanks! That worked just fine.
Hey! How did you get this to work!? I am having the same issue and not able to find a work around. TIA!
Hi Shelby!! This was a problem from two years ago and two versions of Topaz. I didn’t have this problem when I installed the most recent version a few weeks ago. Anyway, here was my response from Nov 2022:
“I got help from Topaz technical support. There is a known issue with Sharpen AI install where it needs certain permissions for a folder. The easiest workaround is to let the install program create the Sharpen AI folder rather than create it yourself. Start the installation with the Sharpen AI folder not created and when prompted for program location just change the drive letter.”
I hope this helps. If not, consider upgrading to the latest version. I know. I know. It’s a lame answer.
