Presets viewport is cut and without a slider for scrolling
Hi Topaz labs,
I experience an UI issue with the presets viewport without a scrolling function ! See this screen capture :
On the right side at the top, the presets viewport has not scroll bar and some presets are hidden !
Please let me know what I did wrong as usual !
Thanks a lot for your help or fixing this issue…
Best regards.
Vincent.
You will need to use your scroll wheel to scroll within the presets window.
Here is a screen recording on how to do this
I don’t know about Vincent’s situation, but I don’t have a scroll wheel, I use a trackball because of a wrist injury. I’m also using a Mac Studio, not a laptop, so there’s no scrolling option on presets whatsoever.
If you have a trackball, you will scroll the ball.
