Hi - I have already asked for changes with presets – and I do it here again:
pls replace auto pilot settings when choosing a preset since I do not want to combine these settings rather to switch between.
Now, after having used presets for a while, I do not like that presets settings stay there, when I choose a different preset. Pls remove the existing settings from the first preset by the ones chosen with the second preset. Otherwise they interact – which is not waht is intended.
Thanks for listening and implementing
Steps to reproduce issue:
Step 1 create preset - choose it
Step 2 choose second preset – you have to remove settings from the first one…
Thanks for sending that in. To help with this request, you can disable Autopilot from running on your image automatically by going to Preferences > Autopilot and disabling the option Automatically apply filters.
Let me know if that works for you and if you have any other questions regarding this you can ask me here
That’s not the point. I know this and I do it already. The problem is that presets get stacked on top of what was selected before – and this does not make sense – at least not for me… I want them to disappear as soon as I use Autopilot or choose a different preset…
Thanks for your reply and my apologies for not understanding your initial request. I have moved your ticket to our Ideas section on the Forums so that your input can be reviewed by the appropriate development team. Your feedback is 100% valuable! We greatly value our users’ feedback and take each request into consideration when working on updates and improvements. It helps to give us more insight into what our apps are needed for and, ultimately, what direction we need to take to fulfill that need.
Make sure that you do not forget to vote for your idea
