Positioning Topaz Window From Photoshop Plugin
Hello,
I have two suggestions especially for the windows photoshop plugin.
Is there a possibilty to open the topaz main window at the same position as ist was closed the last time. I’m using a 3 monitor setup and it is always opening on the “main” monitor and I need on the color calibrated Monitor with the high resolution. Is there a setting to achive this. With the standalone Version I haven’t tested yet, because i’m using it rarely, only for upscaling pictures, which is not possible in the plugin.
The secondis, because you have an excessive lst of options to choose from (which is great), could ther be an optin to put the user settings on top not at the bottom of the selection list
Thank you in advance.
joergens.mic
P.s. I’m more tha satisfied with the possibilities you gave me to enhance / correct mit photos with your tool.
Thanks for the suggestions, and we’re glad to hear you’ve been enjoying the enhancement and correction tools in Topaz Photo!
At the moment, there isn’t a setting to have the Photoshop plugin remember and reopen on a specific monitor or at its previous window position. We can definitely see how this would be helpful for multi-monitor setups, especially when one display is specifically calibrated for photo editing.
We also appreciate the suggestion to place user presets/settings at the top of the selection list rather than at the bottom. With the growing number of available options, we can see how that could make frequently used settings quicker to access.
We’ll share both suggestions with the development team for their review and consideration as we continue refining the workflow.
