when loading pixel 8 pro raw image the pic comes green
DxDiag.txt (112.9 KB)
I have exactly the same problem. This problem occurs with every RAW (dng) file from my pixel 8 pro regardless if they have 12MP or 50MP image resolution.
Lovely. You should report this in the Bugs and Issues.
You’re right. I moved this thread in the Bug’n’Issues section
I believe it was only released October 12, I would guess that it isn’t yet supported but you can check from both the Topaz Labs website and the LibRAW supported cameras.
And for those who think it is a bug, not so if it isn’t supported.
4th October. How long does it take?
You will have to ask support. Raise a request at the main website.
I meant generally.
