Picture processed with Topaz AI have a greenish tint
Some CR3 pictures get a greenish tint when processed in Photo AI
Steps to reproduce issue:
  1. Step 1: in LRC, file, plugin extras, process with topaz photo ai
  2. Step 2: let the processing run
  3. Step 3: save to LRC
Topaz Photo AI [v1.2.8] on [Mac]
Try using the Edit in option and send a TIFF to process to see if that makes a difference.
Hello AiDon!
I have the same problem. I used the workaround you suggested, but it shouldn’t be necessary. Now I have to take the extra steps with a bunch of images. When will Topaz resolve the issue? I’m using Capture One 2023 with an M1 Mac Studio Ultra and the camera is an EOS R5. By the way, thank you for the suggestion. Topaz Photo AI adds purple to the mix. The bottom photo, Topaz Photo AI Denoise was not used. See the difference in the sky and pavement color? All settings are the same for all 3 images. Topaz Photo AI is making me do a lot of work. Denoise does remove the noise.
We’re working on releasing exposure and color correction models with v2.0 on September 7! Please update when that’s available and it should be able to fix conflicts like these.
Hi tim.he! Thank you for responding. Okay, I’ll update when it becomes available.
