I just upgraded to Photo AI v1.0.10 now it won’t work as a photoshop plug in. It says can’t find file. How do I fix this.
Bob
Bob
If you had Photoshop open at the time of the upgrade reinstall Photo AI as you probably have the previous .8bf file in the PS plug-in folder. Make sure PS is NOT running at the time.
Thank you! After reinstalling it a few times with PS not running, it is all good.
Thank you again.
