I have just updated to Photo Ai 3.2 and have the following problem when using the Denoise function: Even when Minor Deblur is set on the lowest setting-1, it is over-sharpening images to the point of being unusable. Hopefully you can turn this down a lot.
Can you share some examples of this oversharpening you are receiving while using this enhancement?
Thank you, I will do that the next time I’m editing (hopefully this evening!).
