Hi. I’m finding that the AI is over sharpening. I’m having to manually turn it down. can this be fixed?
You can go to Preferences > Autopilot > Sharpen and set the Model Strength according to your preferences.
The default is set to Normal, so if the AI models are currently overprocessing your images; I would recommend setting the Model Strength to either Less or Weak and then clicking Save
You can always revert back using the ‘Reset to default settings’ option.
More information:
