Hi, OK not sure what is going on her but if I send an image from On1 PR to Denoise when it comes back to On1 and I set white and Black points it works as should but if I place an image direct into Denoise and save it as a DNG file then open in On1 I cannot set a black point. Please see images, the black point is not blue just goes a muddy black colour. Thankyou, Russ.
I would suggest you ask on the ON1 forums as it is a processing issue with DNGs / ON1, Topaz have no idea how they process DNGs.
And, just FYI, I use Photo RAW but don’t use DNGs produced by other apps.
