Topaz has installed several folders in my Applications folder. It seems disorganized.
There’s a folder “Topaz Labs” with several sub-folders as well as photoFXlab, Adjust 5, Fusion Express 2, Simplify 4, and TopazSoftwareManager
There’s a folder “Topaz Labs LLC” with Adjust AI, DeNoise AI, Gigapixel AI, Mask AI, and Sharpen AI
There’s a folder “Topaz Studio 2” with Studio 2 and UpdateManager
Topaz Impresion 2 is an app without an enclosing folder
Can I put all these apps in one folder? How about components.xml, InstallationLog.txt, network.xml, and three files for UpdateManager? How about the folders Licenses, Common, Docs, Installation, photFXlab, Plug-ins, and pluginApps? Where does jfd_Skin_FixSoft-1.tpp go?
As described by tn-22914] I’m using Windows 10 and Topaz programs are installed in too many different folders-too disorganized and a pain to link them to a host program. I know this forum is for support but if any Topaz programmers read this perhaps they can develop some consistency into one installation folder.
What folders? Not including the legacy products which won’t be updated, you can change the install folders to suit how you want to organize your PC or you can accept to the default which is Topaz Labs LLC but I think JPEG to RAW and Adjust AI default to Topaz Labs folder.
