Order of Using AI Models
When selecting Enhancements option in Video after loading video to be processed, small yellow stars appear on the top right corners of suggested AI models to use.
A video I have at present loaded, the enhancements option has suggested using Proteus, Nyx, and Rhea AI models.
Questions -
  1. do I use only one of the suggested AI models, and if so, which one?
  2. do I use two or all three AI models, and if so, in which order should the AI models be applied? Does the order matter?
You would choose one of those models to run under the Enhancement tab and its best to run a short preview for each of them to see which one you like better for your content.
Here are a few quick videos that might be helpful as you work through the app.
Overview of Topaz Video
Upscaling in Topaz Video
Frame Interpolation basics in Topaz Video
You can also go to the Topaz Video User Guide to learn about the app, and you can further explore the filters and functions.
Thanks for the comments.
So it is a matter of trial and error to see which model gives the best result. This can be time consuming if having to try all possible settings of the models.
In the case of my currently loaded video, the models Proteus, Nyx, and Rhea didn’t produce the best result. So far, it appears that the models Iris and Artemis produce much better results.
I can’t use Starlight (mini) as I only have 8 GB of video memory, unfortunately.
