Hello,
I am a beginner in Topaz Video.
I can’t go faster than 0.8 fps (And I am more often around 0.6 fps).
I have a 2080 TI, an I9 9900K, and 16 GB of RAM.
Is this normal for my configuration?
I’m using Proteus to upscale from 1080p to 4K.
Also, could you give me an estimate of fps with a 3080 TI /3090 TI/4090 TI?
Thanks in advance for taking the time to answer a newcomer in the world of AI
Thanks Imo
Knowing that, I hesitate between the 3 graphic cards above.
Is it possible to give me about the fps for each?
Still with Proteus or Artemis (1080p at 4K)?
I have already seen your video on this subject, I thank you and I will do it
I would still like to know the difference in speed between the graphic cards, if you or another person can give me estimates?
Nice, good to see he used the old Topaz. But the benchmark shows 300% more but his test gives only 90%. Maybe one should look into GPU memory size more?
I have a much slower speed than him, even when he uses his 1060.
I’m at 1.40 seconds per frame (the same under the previous version of Topaz).
So there is a problem, isn’t there?
I suggest to uninstall the old version and then install the new version, not to overwrite the old version with new version. Perhaps you will find out a huge improvement of speed.
For my example, I overwrote the versions from 3.00 to 3.04, and the speed was always slow. Recently I decided to make a clean so uninstalled 3.04 then installed 3.05, finally the speed has improved by 100%.
