Noise Reduction Issue
Hi
I was testing out noise reduction on this photo and you can see Standard v2 generates some very odd artifacts in the photo in the smoke.
Can you upload the original image? I’d like to test it out on my end and see if I can reproduce the artifacts.
Hi Tim,
I can not upload the tiff file I used, the system will not let me.
Shall I send it via WeTransfer or something?
Sure you can create a WeTransfer link and post it here.
Here you go
I was not able to reproduce the artifacts. Please update the app because we’ve made some changes to the Remove Noise models. Standard V2 is now Standard and V1 Strong is now extreme.
Let me know if the artifacts are still happening after you update.
I will do that, Thanks Tim.
