I’ve just exported my first videos and none of them have audio.
I didn’t notice until I had done 4 videos.
I have an Intel i9 with a 4090 card.
Latest version was updated before I started.
UPDATE: I converted the .MOV to .MP4 and then when I did the same export, it kept the audio.
So something to do with the .MOV?
Should it work with .MOV files?
This is likely a sign of format issue between the video and audio files. Switching the audio mode from ‘copy’ to ‘convert’ in the export settings will likely resolve the issue as well.
