Need to use product offline whilst travelling Africa
Hi,
I will be travelling Africa soon and need to use the product offline as the internet connections will be spotty at best and very expensive at worst. Please can you advise how I can do this as testing has shown that models keep being downloaded when I change presets.
Thank you,
Hi @stephen.cartwright, you can download your models in advance by using the model download script here!
One of our agents, Tony, is also responding to your support message if you have additional questions :slight_smile:
