Just edited a nef in Studio 2.0.9 and saved it as a project file. Subsequently exported as a jpeg and all the original exif/metadata had gone. Even the date originally created. A bug surely?
Yes you are right, from NEF to JPEG is OK but not from TS2 to JPEG, and exporting from the TS2 doesn’t bring up the dialog for choosing the output format and also the thumbnail of the JPEG exported from the TS2 is not correct @russelltarpley
