Using newest version of MaskAI (1.3.8), Photoshop CS6, Windows 10. All masking and save functions seem to work fine - both stand-alone and plugin.
Opened from PS as a plugin, create mask, then Apply - the layer I’m working on is updated to include the masked areas as transparent. Setting the Save Options preferences in MaskAI (PS: Auto Create Layer & PS: Save to Layer Mask) seem to have no effect whether the switches are on or off. They seem disabled, like a light switch not connected to anything.
I can work around this by duplicating the layer and adding a mask to the layer before opening the plugin, but I thought this functionality was added several versions ago. What am I missing? Thanks.
