I vaguely remember seeing this mentioned in the forum some time ago. I’m seeing the same problem, the brush overlap is larger than the selected size, and it’s driving me crazy when trying to clean up a mask. It doesn’t happen in Remask 5.
If you are a laptop like me, you may have dual graphics cards.
Please try to disable one of them through the device manager. It may solve your problem.
If the above can indeed enter remask ai, then it is recommended that you use intel hd graphic driver as a non-DCH version.
My issue is in my desktop.
Thanks everyone for the feedback on this. We’ve addressed the new issues with the brush size in Mask v1.3.7, and fixed some crashes.
Will continue to dig into more issues with crashes for the next version. Thanks everyone and we really appreciate you sharing the issues you run into.
