Last night Mask AI was very crashy for me. I mentioned it in the Paid Upgrades thread. The discussion was trending toward technical support, so I am posting here to keep the other thread on topic.
Recap: Mask AI kept crashing during Compute Mask with AI enabled, when processing one specific layer. It worked fine with another layer. Even when I isolated that layer into its own Photoshop file, it would crash. I exited and restarted Photoshop and tried again, Mask AI would still crash. GPU on or off, crash. It would not crash if I used Contrast instead of AI, but the Contrast results were very poor. I ended up using a different technique within Photoshop to mask that layer, then posted my minor rant in the Paid Upgrades thread.
So now it’s a new day. I decided I would try a few methodical tests to see if I could isolate it further before posting that image here for others to try. The plan was: put the layer in its own file (as I did last night), make sure it still crashes. Then reboot the computer (last night I restarted PS but didn’t try rebooting) and try again. Then try Mask AI standalone instead of inside Photoshop. Finally if it still crashed I would post the file here.
Result of the above: I put the layer in its own file in Photoshop, ran Mask AI plugin, and it did not crash. Tried it in the original file with all the other layers, it did not crash. I can’t make it crash today. Since last night I have not rebooted so it should still be close to the same state as last night. The main difference between last night and now is that last night Lightroom was running, while earlier this morning I had shutdown LR for an unrelated reason. So I launched LR, launched PS from within LR, Mask AI within PS (the exact workflow I did last night) and it’s still not crashing today.
I can only imagine Mask AI was crashing due to some issue with PS with how it uses the GPU or memory management. A few days earlier PS was doing some weird things that were resolved by restarting PS (although last night restarting PS had no effect). I am running the latest versions of all software: PS, LR, NVidia GPU Studio Driver on Geforce GTX 1070, Mask AI, Windows 10. I have 32GB RAM and monitor memory usage in Task Manager, the system was using less than 50% RAM at the time. There were no computer resource usage issues last night as far as I could tell.
At this point I don’t need any specific help, but you can see how frustrating it’s been.
TL;DR after sitting overnight the crashes stopped happening
