Low FPS on RTX 5090 With Starlight Mini
On the latest 1.0.4, I am getting good quality output at 4x upscale, but my performance in terms of fps is 0.2, which I consider disappointing on my 5090.
I tried various versions, from 7.0.0.1.b - thats giving me 0.2fps, 1.0.2 (or 1.0.1) gave me 1.0fps! Which was great, but poor quality of course.
I’d settle for 0.4fps. Is there a version (or settings) that will give me good quality but also good performance?
Here’s what I’ve tried:
  • Updated to the newest NVIDIA studio driver, clean install
  • GPU memory usage, tried 100% and 85%
  • Number of processes, tried 1,2 and 3 (no difference)
  • 4x upscale 480p to 1920p, outputting a ProRes422HQ (tried TIFF, same 0.2fps)
  • AI Processor NVIDIA geForce RTX 5090
(I bobbed my original interlaced footage to 59.94fps.)
Hi Ian, I’m sure resolution was not the same for the comparison. Speed of 1.0 fps is when you do 960p, higher resolution is slower. Choosen output resolution matters (not really scale factor). When going to 1920p/2160p, then I also get about 0.2fps with my 5090.
unfortunately, the output resolution displayed in the output window is not always correct. It can show you 1x or 2x but does 4x or vice versa
I guess I’ll just have to accept it.
I did try and frame blend with optical flow back down to 29.97, I’ll do a test to see how that affects the motion.
Otherwise I’m stuck with a 15 min video clip at 59.94, 4x upscale which might take a day and a half or so.
I’m trying to work out the electricity bill how that might be affected. Maybe $15 for that day-and-a-half job?!
Hi Ian, to bost the speed i use MSI Afterburner, it is overclocking the GPU, i use +260 for the GPU and +200 memory clock, i usualy restart my pc and only start topaz and afterburner, then i use Topaz over the night and run no other programs, my feeling is that it work fastest that way.
I uppgraded my system from dual xeon to AMD Ryzen 9, 7950x3D i did it with the older Topaz video, befor starlight sharp version was out, it gave me a performans bost off around 10%
I did the opposite and limitd my 5090 gpu to 850mV (and ram clock can be maxed out). So here I wrote the TDP drop ist bout 150W but it’s more like 200W less or 30% lower TDP. Sure there is a speed loss, about 8% cpmpared to the factory card but for me it was worth because of much lower power consumption, less heat, handwarm 12V power connector
@thomas.winqvist - I might try that and see what results I get.
However, @Mayday , thats good info because behind my request is the desire to lessen the heat load, and save some money on the electricity bill.
Although I did ask AI to estimate the cost, and it turns out its not a huge difference.
Does this below, look about right?
On a 36 hour job, its estimating vanilla:
0.75 kW × 36 h = 27 kWh
Cost at 14.6¢/kWh:
27 kWh × $0.146 ≈ $3.93 → call it $4.
Overclocked:
Energy: 27 kWh × 1.09 ≈ 29.4 kWh
Cost: 29.4 × $0.146 ≈ $4.30
Undervolted:
Energy: 27 kWh × 0.76 ≈ 20.5 kWh
Cost: 20.5 × $0.146 ≈ $3.00
Scenario Relative Power / Time kWh (≈) Cost in your location(≈)
Undervolted (850 mV) 0.7× power, 1.08× time 20.5 $3.00
Stock baseline 27 $4.00
Overclocked 1.2× power, ~0.91× time 29.4 $4.30
I live in Sweden so my energy cost is different, $0.146 seemes pricy.
my consumption is
when GPU run att 2782MHz it consume 950 mV and when OC 3127 MHz 1045mV
Here in Germany we have about 0,35-0,45 € / KWh - so not pricey at all from that perspective.
(But then I am lucky to have PV and being autark to ~95% with that so I don’t care that much).
Yeah and here in Switzerland we have simillar energy costs. But I’m not just concerned about prices, I’m also concerned about waste heat and noise levels, and primarily about protecting my expensive card. Are you familiar with melting 12V connector?
Ian, i ask ChatGTP and got this formula, kWh=Volt *Amper * time / 1000 (divided with )
measuring (with CPUID HWMonitor ) when i run SLS with OC (+260),
i get this power cosumtion
1.050 * 46.82 A * 16h = 737.4 / 1000 = 0.737 kWh pleas check your self.
my elecric consumtion for my house in sweden , heating the house in october, cooking, warm water …. was 1709 kWh. my guess is that 36 h cost you 0.258$ plus the other part of your pc so topp 0.5 $ for your 36 h work. if someone find my calculation totaly wrong pleas coret.
I ran that through my ChatGPT thread, and it gave me this feedback.
Compare that to his guess:
“36 h cost you 0.258$ plus the other part of your pc so topp 0.5 $”
He’s under by around a factor of 6–8 because his measurement only “sees” ~49 W instead of the 500–700 W your whole system is actually pulling.
He measured the hamster running inside the GPU and forgot the entire treadmill, room lights, and air conditioner. His formula is fine, but he’s multiplying core V × core A, which dramatically underestimates real GPU/PC power.
Yes, you can calculate it much more easily. Simply take the average total PC power consumption during rendering and multiply it by the runtime, the number of hours, to get the amount of energy in kWh. There are energy meters that do this for you. They are not very accurate, but they are perfectly adequate for this purpose.
And even that is a VERY optimistic number.
A fast PC with a 5090 card will very likely pull more than 700Watts for the whole system. The gfx card alone likely draws up to 600W under heavy load (with some spikes even higher).
Then there’s the CPU, RAM, mainboard, HD, fans - if you leave the monitor on that’ll use maybe 100Watts, too.
Monitor will be off.
I will see what happens. I don’t know how hard Starlight (Mini) is working my GPU.
I did try Starlight Sharp, and that model is working my GPU very hard, like having a jet engine in my room. SLM seems not to work it that hard.
I might get an energy monitor to check it out, I see them on sale for about $12 now.
SLS giving me 1.8fps, but not the quality on ground textures, and some “distant” faces it distorts.
SLM giving me good quality, but 0.2fps.
SLM uses my RTX4070 12GB nearly 100% most of the time.
I have put a power meter on my PC: Less than 600W while running SLM, at the moment it shows me highest peak of 565W. My 850mV undervolted 5090 keeps below 400W consumption (read out with TechPowerUp GPU-Z), my CPU Usage is most of time below 50% load. There are three SSDs into my PC and eight fans
I think a better way to do speed comparisons for the Starlight models is to set the processing speed display to seconds/frame instead of frames/second.
yes it is, but we are not used to, higher values meaning slower. They could just add an extra decimal place to the fps, was already requestet, but without Topaz reaction
I finally got around to getting a fairly precise dollar price for my renders using a power meter.
I just rendered out a 2 day job on my 5090. 2 days, 3 hours, 43 minutes.
3x upscale on around 15 mins footage to 1440p.
61.67 kwh were used.
Price per hour: $0.14
Power company price per kwh: $0.1196
Total estimated cost around $7.37 (low estimate $6.90)
Hmm, but if you rendered for about 52 hours and used 62 kWh, then the average power draw was around 1.1 kW, or I’m wrong? My PC (with an 850 mV undervolted 5090) draws about 650 W.
